So I am ready to give up on the Chaparral, needs some new rings. Anyhow picked up a 20 hp Kohler, now it's time to fashion up some engine mounts and figure out clutch alignment.
Looks like the original clutch will mount to the 1' shaft on the Kohler so lucked out there but now I have to worry about belt size and transmission alignment. Also after some reading I found that I also may need to change the weights in the clutch to get it to engage at the correct RPM.
I am going to take the engine & transmission over to the fabrication shop on Monday, was hoping someone has already been down this road and could help me avoid some headaches.
I am going to use measurements from my old motor to ensure I am aligned to the driven pulley easy part. The problem is I will more than likely have to move the engine further away from the transmission as I need come clearance between them. Looks to be about 1-2 inches.
So the belt will be my biggest problem as I can tell so far, I have no idea what size belt I should have as I didn’t get one with it.
What is the stock belt used with the old G44B's? Figure as I am using both the clutch and driven clutch from the original set up, the belt size should be the same but a bit longer. And of course I want to be able to get replacements so if they aren’t able to order one I might have to rethink the clutch system and replace both along with the belt but a new clutch isn’t cheap so if I can avoid it that would be great.
Figure if I move it 1 inch further away from the transmission will need 2 inch longer belt.
If anyone has experience swapping out engines please point me in the right direction.
On a side note I have g44b with electric start for sale needs rings.
