I have a 18hp ic that starts great will run for 5-10 minutes. It starts loosing power and has poor acceleration until it stalls out. I checked the gas cap, I still need to check the spark, I am thinking that the valves need adjusted? The carb was clean when I put it all together and I installed a low psi electric fuel pump, so I am sure it's getting gas.
18hp ic Problems
Start it up and run it till it stalls, check for spark and check compression. Could be the magnetron getting hot and losing spark, compression could be weak when hot.sigpic
