I was riding around in my 2005 argo avenger for about an hour. Stopped the engine from running for about 20 minutes. Started the engine and found out that the one spark plug wire was not firing to the spark plug. What is causing the no spark? the coil or something else.
No Spark
How'd you make out with this, are you still in need of help? I'm not sure I understand. No spark at the spark plug, or no spark comming from the coil? I would replace the plug, if your problem still exists, make sure the spark plug wire cap is securely on the wire. Make sure the cap is making a good connection on the spark plug. Check to see if the spark plug wire is damaged. Look for any loose connections at the coil. I hope this helps.Last edited by Paul219; 10-18-2013, 04:24 PM.
ThanksOriginally posted by Nubs View PostThe wire Assembly part # 692319
Looks like it is compatible with these horizontals and about 100+ other B&S models, but always double check.
The 30 series is the 16hp V-twin
304400 Series (0300-0416) Engine
303700 Engine
384445-0112-E1 EngineThe trouble with retirement is.... I never get a day off !!!!
