Got the engine running and starting good (man this things fast for a newbie), now i just gotta get the charging system working.  Looking at the drawings I'm seeing a rectifier.  I don't have the rectifier, and there's not a snowmobile within 200 miles of here. lol  Can a rectifier be made using diodes, or am i not thinking right here?
ccw 400 rectifier
Can you verify that you have ac output from the charge coils? Usually 2 yellow wires coming out from behind the flywheel. Should get somewhere around 14-25 volts ac depending on rpm. I usually order universal rectifiers from Shade Tree. I can't find my book tonite but they have a web site. Probably need one that will handle more than 15 amps. I don't think the charge coils are above 15 amp.
You can get aftermarket rectifier/regulators pretty cheaply. I'd try Manufacturers Supply. Most any unit made for a two stroke 12v system will work.Stuck in the seventies- not in the swamp.
I would guess that pretty much any rectifier that rated for 25V or more at 25A or more ought to work, and give you enough margin to last a long time. That ought to just cost a buck or two. If you can't find one, let me know and I can mail you bridge rectifier module that will do what you need.
