Well been thinking quite a bit about this addition of the Kubota diesel and a turbo to it. The engine is water cooled but not a pump fed system it's strictly a rad filled, sitting on the block filled and hot water from block and heads rise and cooler water sinks, there is a engine driven fan to force air through the rad as well.
The engine has a pressurized oil system with a spin on filter, and I"m thinking of adding on an external oil cooler to assist the cooling of the engine.
The engine is as we know set down in a tub and does not see much for air flow and I really want to add a cover to help quiet things down, I'd also add a separate cooler for the transmission as well to assist keeping it cooler.
Any thoughts on a good small engine oil cooler, anyone have experience with them?
Look forward to hearing from you all.
Al
Al
MUSCA TUR BOTA then eh?
