B&S 18hp Crankshaft size
  • B&S 18hp Crankshaft size
    Can anyone tell me the crankshaft size on a 18hp, B&S vanguard engine, it's on a 1999 max iv not sure if that makes a difference. Looking for shaft diameter, length and what size the shaft is tapped to. Thanks.
    It's a straight 1" shaft with a 1/4" keyway. The length is just a hair under 3".
      And anyone know the bolt and thread size in the end of the shaft that holds the clutch on. Thanks.
        Most are 3/8-16 from what I run into.
          I guess what I'm asking is this, on a 1999, Max IV, 18HP B&S engine. What is the Model Series Number? Should be 6 digits- 4 digits-2digits?
            Its all on the tag on the fan/flywheel housing, right side if I remember right.
              Tag, data plate not there missing, fell off, and or removed by a previous owner? So I have no idea of the Model and Series No. which is needed when ordering parts. B&S has so many Models, thought I could go online and figure it out. I find models close but no cigar.
                Well if its a 18hp then model #356447-0213-b1 will work for everything but the crankshaft and carb, those two are where most of the different versions come from. the last six digits
                  this may help
                  Parts and Diagrams for Briggs and Stratton 356447-0213-B1
                    Thanks, this info will really help a lot.
