jlo 295 tillitson hr carb rebuild kit
  • #16
    Originally posted by laptop4079 View Post
    Do you know any thing about what carb to use or anything about the conversion? Any info is appreciated
    I think the 295 came with a VM28 flange mount type. You should be able to use the same insulator block that was used with the Tillotson. A Mikuni wafer type pump is all you'll need to supply it and there's a port on the back of the block to pick up the crankcase pulse to run it. There may be a plug in the port instead of a barb fitting, but one of us will have one for you, I'm sure.
    Good luck!
