I have a 24 hp Honda motor with a Salsbury centrifugal clutch does anybody have the number to the company Salsbury or know what belt is supposed to be use for this set up I have a model number of 1190 and 1195 but not sure what that means
24 hp honda motor with salsbury clutch
hi
contact quality drive systems
CVT clutches work as a complete 3 piece system BOTH CLUTCHES AND BELT
If the fitment is in a 6x6 ,
then a 32 degree ramp with a red spring secondary ,
Primary is first setup for the engagement rpm u want . Use the heaviest weight for the greatest clamping force with the appropriate spring to achieve an engagement seed of 1500-1600 rpm
belt selection is width for the clutches used and length is for the cen to cen distance calculation
tomo
Once you have the CVTs in their final positions, just measure the distance between the centers of the CVTs and when you call quality drive like Tomo recommended, give Roy that distance. He will know what belt to give you. If you google quality drive you can find his information: Quality Drive SystemsOriginally posted by acro628 View PostHow do I determine the length it is installed. does anybody have the number for the companies that I can call them?
