While I was installing my new engine I broke this piece, I can't find it in the parts, someone know what it's called? Can I just gorrilla glue it back together? Any help would be appriciated... This looks so much bigger than the briggs.   Thanks.  Norm.
27hp kohler question
Originally posted by Normable1973 View PostWhile I was installing my new engine I broke this piece, I can't find it in the parts, someone know what it's called? Can I just gorrilla glue it back together? Any help would be appriciated... This looks so much bigger than the briggs. Thanks. Norm.
Try this out for size Lawn Mower Parts, Small Engine Parts & Much More! | PartsTree.com - Briggs, MTD, Toro, Cub Cadet, Husqvarna, Troy-bilt...HUSTLEMANIAC and a HONORARY MEMBER of the
BIGFOOT ALUMNI
Hi Norm, here is the parts diagram for that engine: Lawn Mower Parts, Small Engine Parts & Much More! | PartsTree.com - Briggs, MTD, Toro, Cub Cadet, Husqvarna, Troy-bilt...
Number 24 is the entire fuel pump, number 31 is the upper fitting in your picture. The fitting is cheap if that is all you need. Should be able to order online or from your local Kohler dealer.Everybody dies, but not everybody lives.
We'll I got the trans installed,made some brackets for the top front and back to stop it from moving. Then when I went to install the kohler I realized the bolt holes on the engine stand from the 18 vanguard were wrong so I welded them up and punched new ones, then the stand seemed flimsy so I made some plates that go under it and cross braced the legs. The new belt came in today so it should be just about complete tomorrow... I rebuilt the t20 that I took out of it for the max 2 so I will have both machines complete very soon!! I won't be disabled anymore Jim... Lol. Norm...
Looking good Norm. There is plenty of beefing up to do when you add power to a Max. Newer Maxs have the legs of the engine stand reinforced also. Angled braces welded onto the legs down to the feet to give it more strength where it bolts onto the frame/motor mounts. A large engine could bend those as the engine pulls itself down toward the trans.Everybody dies, but not everybody lives.
Hey Norm I got you when I get there tonight. the Kohler starter takes two wires ( one red battery, and one green remote/ignition from key wire) then there is one black wire to kill the coils, and another white wire to recharge the battery that comes from the Stator. I can show you it tonight, so dont worry,,, you'll be running in minutes!! looking good though,,, we should have some time to take it for a spin in your creek/river behind your house tonight maybe!!HUSTLEMANIAC and a HONORARY MEMBER of the
BIGFOOT ALUMNI
Well was he impressed?Originally posted by fmints View PostHey Norm I got you when I get there tonight. the Kohler starter takes two wires ( one red battery, and one green remote/ignition from key wire) then there is one black wire to kill the coils, and another white wire to recharge the battery that comes from the Stator. I can show you it tonight, so dont worry,,, you'll be running in minutes!! looking good though,,, we should have some time to take it for a spin in your creek/river behind your house tonight maybe!!
with the new engine, older style clutches it should be far superior to what he had.sigpic
  Perhaps they killed it and there's now real tears
