New to the site. I just picked up what I believe is a late 70's 6 wheel argo with a Kohler 3992t engine.
1. What is the part number of the air filter I need for replacement.....round air filter 5 inches inches wide with metal housing.
2. Machine is starting but on occasion the starter will sieze up and I have to manually turn the belt wheel to disengage. Should I get a new starter and if so part number for that.
3. Plastic gas tank is cracking and has a few leaking areas. I called relics and they say the gas tank that has the filler on the left side is no longer available. Solutions? Can I use an epoxy sealer internally?
Thanks. New to this and want this beast to get deep in the bush to do some trout fishing. Picked this unit up for 1000 bucks. Had an engine/carb rebuild 3 years ago and then was put away till now.....Took us about 10 min to get it running....New tires and bearings too. I think I got a good deal.
Jordan
Jordan
