i need to know how long and what size threads for this bolt. thanks
18hp briggs with comet 780 series clutch bolt size?
The proper answer would be "a bolt long enough, but not too long"
The question is not a simple one. Crankshafts vary and some applications take spacers that move the clutch out farther for alignment.
I'd look for a bolt that gives you at least 1/2" of threads into the crank, and 3/4" would be better. Just be careful not to bottom out the bolt in the hole.
The 18hp briggs probably takes either a 3/8" or 7/16" fine thread bolt if you are looking for diameter?
Originally posted by thebuggyman1 View PostThe proper answer would be "a bolt long enough, but not too long"
well thread pitch helps i didnt think there would be that big of a different in cranks... my crank isnt that long(6-8inchs) so i cant space much but will have to have it spaced some
thanks!
