I have been working on my Max2 motor I have added a timing advance key and new springs. I have finally had the chance to install it back into my project machine and have found that once its started I cant turn it off. The only way I can shut the engine down right now is stuff a rag into the carb and choke it.
I have checked out all the wiring and it all seems to be correct, all the ground are also connected with a big ground strap to the base of the motor.
I have done some troubleshooting from the manual and it all points to the diodes being bad. I am some what confused on this because it was working fine before I took it apart so how do these diodes just fail for no apparent reason or could it be something else I am missing. any input would be greatly appreciated.
