Kawasaki FD620D Liquid Cooling System Issues
  • Kawasaki FD620D Liquid Cooling System Issues
    Hello everyone! I'm relatively new to Argos and completely new to 6x6world.com (this is my first ever post). I regret to say that my need for help with an engine problem I'm facing right now outweighs posting a proper introduction; my apologies for that. I have recently bought a 1997 30th anniversary edition Argo Conquest 8x8. I'm just out of high school and still working my first job so it took a slap year of putting away nearly every cent I made to afford the $5,500 CAD price of one of these things on the used market.
    Anyway, I fear my ignorance of liquid cooling led me to overlook this issue upon purchase. My engine is overheating. Once it starts up, it will warm up and the gauge will park itself right on 220 degrees Fahrenheit. After a bit, it will go back down to 190 degrees Fahrenheit. Then it will briskly go back up until it hits 220. This cycle repeats indefinitely as long as the engine is running, essentially the temperature is fluctuating. I knew this needed attention, but I figured it was ok to keep driving. I've put about 8 hours on it running like this.
    It got more serious the other day, however, when I was out on the trail and the coolant got up to 240 degrees. It kept fluctuating between 200 and 240 and I had to limp it 30 minutes like that back to my house, there was nothing I could do, not even taking the hood off helped.
    A couple of things to note:
    - The higher the engine revs, the faster the fluctuation.
    - Once, I turned the key on [EDIT: cold engine] and the temp gauge pegged itself without the engine running. I started the engine and it returned to the bottom.
    - The upper rad hose is hot, the radiator is hot, the lower rad hose is lukewarm.
    - The coolant overflow bottle has been steadily loosing coolant.
    I ordered a new thermostat from John Deere, I'm hoping that is the issue, however, it seems as if the cold lower rad hose connects to the water pump and the hot upper rad hose connects to the thermostat.
    I hope you guys can help me, I'm really stumped and being so far out of pocket for something with issues like this is getting me a little worried. Thanks in advance!
    Welcome to 4x4 world.
    I cannot speak from experience with your particular machine however up down or cycling is a normal function in the cooling system.
    I'm not sure if the degree or should I say the amount you are experiencing is normal but hot coolant leaves engine cooler material enters via the lower rad hose as you have explained. Most every vehicle does some fluctuation to some degree or another.
    Waiting for others with more experience related to these machines is a good idea. Changing a thermostat would likely not hurt. Use new coolant of the right type for your engine, and only distilled water few bucks a gallon at grocery or pharmacy store...steam distilled water has no foriegn minerals or such and won't cause the build up in the cooling system you may have seen in radiators.
    What tempurature was the environment that you where using the machine.
    BTW I too am in Canada, BC to be exact, where are you located?
    And some pictures would be nice too.
    MUSCATEER 6x6
    MUSCA TUR BOTA then eh?
    94 F350 4x4 7.3 IDI ZF 5sp
    Al "Camo pants"
      Thanks for the quick reply! It was a particularly hot day when the machine reached 240 degrees. The ambient temp was around 35 C. I live in Edmonton, Alberta. I would have uploaded a couple pictures of the Argo itself and the temperature gauge but my internet was giving me grief and Flickr wasn't working.
      Cheers!
        HI
        First and easily done -change thermostat. Please take note at what temperature is printed on the thermostat is the minimum operating temp 170f [71c],180f [80c],195f [92c] [there can be hotter but unlikely ].This will be the minimum the engine will operate at after 20 min warm up.
        The system needs to be pressure tested at 5 lbs pressure above the radiater cap pressure for coolant leaks . Test radiator cap blow off pressure .[with the same tool]
        Test operating temp of system .Run engine with a thermometer in radiator neck .U will see the coolant flowing and the thermometer will go up and down with the electric fan .
        The fan on -off temps will always be above the thermostat temp
        Only fill system with demineralized water50/50 with coolant or u can buy complete fill [already mixed ]
        Use either a glycol based or a hybrid glcol/OATS.
        Flush old coolant out with house water then fill with demineralized and dump ,u r now ready to fill .
        The hybrid will mix with almost any coolant remains of any type
        Radiators have cooling tubes that block easily .
        A radiator shop can rod the tubes in the radiator [u cannot test for this u just do it ]
        If equipped with thermo fan. Verify operation .
        The electrical sender unit may not be working properly and/or to specification
        Check for corroded water pump impellor [remove to inspect]
        Check fan belt if equipped and mechanical fan if equipped
        Check for blown head gasket [pressurize cooling system and see if water comes out cylinders/plug holes when engine turned over.
        U can also TK check which is exhaust leaking into system .
        Pay close attention to cooling air into the body /engine area and the out let for all the hot air .
        A few ideas ,,,Leave the bonnet off ...bilge fans ...very good ducting with the muffler inside to remove the hot air
        tomo
        Ps in hot weather the 8x8 do get hot in the tropical area I live in . The dealer used to install an additional fan . Where and how I do not no. This came up when I was looking for a used 6x6/8x8.
          My first thoughts are thermostat but my gut feeling is failed head gasket. My favorite way to test head gaskets on liquid cooled engines is as follows. Find an air holder capible of supplying compressed air to the spark holes. A compression tester with the check removed or a spark plug with the porcelain broken out can have a fitting brazed to it. Remove both spark plugs, valve covers me all the rocker arms. Pinch off the tube from top of radiator to coolant tank. Fill radiator to top don't leave any way for air to escape. Apply at least 90 psi air to cylinders one at a time and watch for coolant discharge from radiator. If it holds air for more than 2 minutes head gaskets are good. I've found scratches in heads that were just a black line that leaked under power this way. Parts are available for this engine. Hope you don't need any more than a thermostat.
            Thanks for all the good advice guys! Msafi65: Now that I'm dealing regularly with Liquid Cooled engines, a cylinder pressure tester would be a handy tool to make I'm sure!
            Good news guys (I think). I decided to remove the thermostat completely today and see if that made a difference. I put it all back together and filled the radiator back up with what I had on hand (some no name brand ethy. glycol concentrate and bottled water). It took a while to get up to temperature but it ran nominally and never even went over 180 degrees F. I put it through it's paces with two hours of wide-open-throttle swamp bogging and it didn't skip a beat!
            Since it preforms well with the thermostat out do I need to worry about head gasket failure and/or a bad water pump?
              Probably not, get a new stat and try it out. Also verify temp with an infared tester or contact gauge, as it may be a bad gauge or sender.
                Tomorrow I go to John Deere and pick up my thermostat. I've got to try stopping at Princess Auto to buy one of those infrared sensors, since the gauge pegs itself whenever I turn my lights on. Turn them off again and after a moment or two the gauge snaps back to normal.
                  you might not want to leave that bottled water in your cooling system. As others have said you want distilled water with no minerals in it in your cooling system. Some "natural spring water" types have a lot of minerals in them that settles out so bad that you can see them floating around after long storage.
                    HI
                    Running a cooling system without a thermostat is typically not a good idea
                    Some engines will overheat without a thermostat coolant goes to fast thru radiator
                    Sometimes the opposite happens , the cooling system runs very cold
                    When running cold ........a lot........ of engine wear occurs
                    If the engine overheats with a thermostat installed the engine has an issue somewhere else
                    tomo
                      Originally posted by Tomo View Post
                      HI
                      I assume you mean if the engine overheats with a working thermostat. I recognize the need for a thermostat otherwise the engine would be impossible to use in the winter for the above reason; it would never warm up. I'll just have to cross my fingers and hope that a new OEM thermostat and some good coolant solves all of my temperature related problems!
                        Clean all the connections at gauge,sender, all grounds on ground bar etc. Suspect bad gauge. Also check that the fan belt is tight.
                          Hi Lobsterbox,
                          Did not mean to explain in such a way about that..
                          I have had a thermostat that was stuck /limited movement which caused cycling of the temperature and staying high under load [limited coolant flow ] Basically the engine was cooking itself to death .
                          Poor quality part
                          99% of cooling systems run 180 to 195f [180 is my preference ]
                          The only reason that some cooling systems run hotter is to improve emissions or gain that last 1/2hp
                          They run around the 212f /100c relies heavily on the radiator cap to prevent boiling
                          [pressurized system raises the boiling point ] At 212f u have no margin for error
                          Thats why I asked u to note the thermostat temp . I would be tempted to change the thermostat to a 180f if not already .
                          If the radiator cap has some wear in the rubber gasket at all change with a new one of the same pressure rating [inexpensive]
                          Typically u can buy a radiator thermometer cheaper than other types [dial on a probe ]which helps when doing service work .
                          An infared thermometer will be good when u are travelling along under load and check the radiator top ""tank"" temp [engine out let temp ]
                          Hope all this info helps . When it comes to issues mechanical ,I just enjoy solving them
                          tomo
                            The engine can also run hot if it is running too lean. (wrong jet, dirty carb, ...)
                              Hey Lobsterbox, How do you like the performance of the Kawi?
                              I just picked a 97 Kawi 20HP one up for $50 that had an Oil leak issue. Im going to tear it down but I wasn't sure if it was worth using for a buggy project or if I should just Part it out and invest in a Vanguard.
                              Do you know what year your engine is?
                              Im not sure if your aware, but pre 98 engines had Nylon Cam Gears that Break very easily, causing a tear down and need of Cam Replacement. I read that they used the Nylon Gear due to reduce sound noise. After 98', went to Steel Cam gear.
