vanguard carb swap questions
  • vanguard carb swap questions
    My 18hp carb is junk can I use a 16hp carb in its place and change jets ?
    Yep
      OK thanks I found a 16hp carb on eBay but I have had no luck finding an used 18hp carb
        Many times the 16hp carbs run the same size jets, can't tell Ya why
          Do u think this would work ? Briggs Stratton 16HP Vanguard VTwin OHV 303447 Engine Carburetor | eBay
            I would hold off on that deal for a bit, let me look and see what I have first, thinkin' I have something. I will look in a few hrs and if I do i'll post a picture and we'll go from there.
              OK that would be great thanks
                Ok, think I have what You need. Nikki 6100-22-142, numbers 808880 13L. came off a 18hp, its missing some parts like the float pin and choke shaft n plate but looks brand new inside. jets are all there and also look like new, i'll post a picture in a few hr's.
                  The make of my carb is a mikuni are they interchangeable ?
                    Don't know, all the 12,14,16 and 18hp briggs I run across run the Nikki carbs like in the e-bay link You posted. this is all I have
                      Ran across this? Not mine, just sayin'
                      Briggs Vanguard V Twin 18HP Nikki Carburetor 350447 Cub Cadet Pulling Onan | eBay
                        OK I got a carb that works engine runs but under full throttle the flex pipe to the muffler glows red is that normal ? Or am I to lean on the main jet thanks
                          the color of the spark plugs is the only way to know for sure, dark brown to light tan is good. gray or white and its to lean, flex piping likes to hold heat.
