I have wanted to upgrade my 16hp briggs for some time now and I recently came across what I think is a good deal for a 23hp kohler command pro. Has anyone ever used this motor? And if so what else if anything would I have to do/get to make it possible. Any help would be awesome here's the link to the motor if that helps 23HP V-Twin Kohler Engine
Argo vanguard engine upgrade to kohler
Check the crank it looks big and long, long is not to hard to handle but too big is an issue. 1-1/8 max for clutches one inch is what you'll have now.sigpic
The 1 1/8 clutches are pricier than the 1" clutches too. On the upside, the Kohler has hydraulic valve adjustment so it will eliminate the necessity of adjusting the valves every 100 hours or so as the engine will do it automatically, and you will really appreciate the hp and torque increase.
The Argo Frontier I have has a 23 (B&S) and while the Briggs isn't my favorite engine, horsepower is just about right, so the Kohler 23 will be a great upgrade.
I have a CH20 and a CH23,both 1-1/8" shaft. I use an 1195 drive clutch. I've had both in my green poly sumptincheif and really did not notice much difference between the two. They both have plenty of grunt. I too,like my Kohler engines.sigpic
I had the briggs 18hp opposed in my Hustler at first, but came across a ch23 kohler that had the same 1 7/16 crank. I went to my local junkyard and found a ch18 kohler and bought the crank and swapped it into my ch23,,,, direct fit!!!! I think that I paid about $35 for the crank. You may be able to find one on ebay that will fit your current clutch without buying a new clutch for $220 plus!Originally posted by Adel318 View PostI really appreciate all the information, I just found out the crank shaft is 1 7/16. Does anyone know the recommended drive clutch that can be paired with that size.HUSTLEMANIAC and a HONORARY MEMBER of the
BIGFOOT ALUMNI
