I was wondering is there a difference bewteen the kohler 23hp and the kohler25 hp  as for power would it be worth up grading to a 25 in my max 4 I also see they sell in northern hydraulics a 27hp motor too.
kohler engines
Hi junk. I know this is a bit late in coming but I have been away for a while. I don’t think it is worth the swap at all. I had a max4 with an 18 Briggs and my new one has the 25 hp Kohler and I can’t tell the difference at all. Save the $$
Oh ya the biggest difference I can see so far is the Kohler is a lot QuieterLast edited by BenDawg; 09-03-2008, 10:45 PM.
i have a 18 briggs in my II and a 23 k in the IV not munchg differance . if you go from a 18 2 a 27 yes there is a differance .i rode a 27 kaw iv and there is right munch differance there . robbie1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
   if it don't float with out you getting wet .  don't bring it !
    R.I.P  sage rogers   4 11 09  .
      you can't fix stuped  !!!!! raceone 3 .)
you are rightOriginally posted by thejunkman View PostI ended up buying different sprockets for the t-20 to drop down from a 15 tooth to a 13 tooth like mightymax did hows yours for power rdr I think the 23hp is not enough for the max 4 with 26" tires1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
[ QOUTE ] does your belt squeel at times when taking off ?
junkman ,
I ride with boncrshr who has a Hustler 950 with a 20 hp Honda motor in it . He has also done the red spring clutch modification too . He also went to a 40 tooth sprocket which helped a lot . In situations though , when his Honda motor is put under a lot of strain , his belt will squeel some times too .
He was told that a Clutch off of a Max IV would cure this problem. ? Any one know about this ?
na i use napa belt dressing but be carful a verry little goes a long way: robbie1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
yes it would squeell. not now though i use napa . but be carfull a verry little goes a long way robbieOriginally posted by thejunkman View PostBut before you used the napa belt dressing did yours squeel and what kind of dressing napa or crc?1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
sprayOriginally posted by thejunkman View Postthanks robbie it must be the kind you spray on right or is it the paste I will have to try some.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
