Looking for some info on the Chappy G50B exhaust manifolds what models will interchange with this engine or are there any aftermarket manifolds that will fit this engine so some place that has a used one reasonable or even a place that custom makes them that is also reasonable. Then my next question is which is the best sized Mikuni carb to run I have heard 38 to 44 mm.? Thanks all you folks are always a great help.
Chaparral G50B engine Exhaust manifold
36 or 38mm carburetors work well on the G50B stockers. I don't think any more than that would do you any good. What manifold are you looking for? There are some that use a flex and exhaust clamp, and some that have a ball-and-socket joint.Stuck in the seventies- not in the swamp.
