I have an issue with my walbro carb whg type.  I cleaned it in varsol, wiped it down real well, and used air compressor to blow it out. i put in a carb kit, didnt include the high speed jet.  I tried 2 of them, i had a spare carb.  My issue is that it starts very well but in gear, i have to leave choke half closed or it just stalls, or starves for gas.  i seem to be getting lots of movement from the govenor.  when idling the govenor lever moves rpm gets higher. back and forth, i dont know why it does this.  I tried adjusting the high speed jeta bit at a time and only made it worse.  i could drive all over the place, but no speed. Something in the bowl? Both high speed jets are damaged Any help would be welcome.  Thanks for looking
Tecumseh 16 hp engine
After looking at this the carb is slightly different than the older Tec. carbs, if this is what you have try the k341 setting as that is 16 hp.. Have the needles been removed and ports cleaned? 2+2 is great but don't touch rubber or plastic with it.sigpic
