Hi guys,
Picked up a MAX II with the round headlights (I believe that model has some designation, Big something?) that was in need of a lot of work. I've stripped it down and rebuilt the engine mostly. The engine is a Kawasaki TA440A and looks to be original. It has a Mikuni carb on it. I left the crank in but honed the cylinders and put on new rings and gaskets. The carb to intake rubber was done so I ordered that. New plugs as well. I have not touched the carb at all.
The thing turns over nicely and even "pops" a bit (with some very faint smoke out of the exhaust manifold) but won't fire. One plug wire is missing some of the boot so you can pull it off and see if the spark is there and it is sometimes there but really hardly at all. So I assume we have an electrical issue.
Should I just replace the coils and the CDI? It seems like you can't diagnose the CDI at all and I haven't touched the coils yet, but I figured I might as well just replace? Is there anything else I need to look at (some parts behind the pull start?). As you can tell I'm not really a mechanic but I'm having fun tinkering. I'm doing head gaskets on a F140 5.4l V8 right now and just picked up a 1969 F250 that needs some love.
Any help is appreciated. Can't wait to get this thing running. It came to me with almost NO tension on the chains so it drove like crap. The engine ran but took a lot of love to get going (starter fluid) and smoked a ton. The chains tensioned up nicely with the stock tensioners and some pressure washing took out a ton of dirt and grease.
Oh another question... what is the chain greasing/lube situation? Do I slather them in some thick grease or just some light lithium grease?
