So I think I have 2 problems the first I think I solved with a fuel pump after a full throttle run the engine would stall and take 30s cranking to start found out the carb ran out of fuel so after that junk was sorted out.
I found that the bogging issue never went away.
So at idle in high , low or nuteral if you go full throttle the carb will spit fuel into the air filter and chugg with no increase in rpm and if you hold it it will stall.
I cut the plastics retainer off the idle fuel screw leaned out the carb and found fuel setting has no effect of any on the problem at hand , checked valve lash witch is in spec , new spark plugs ngk fr45 I think gapped to .030" cold start open or closed this happens carb is clean and fuel level is correct in the carb
Any ideas please help
Carb parts are expensive and had to find
It has a Nikki car on it as well
Thanks for the help in advance
