hey guys,i swapped the 14hp with a 23hp vanguard.will i be ok using the same muffler and flex pipe that the max11 came with? it sounds ok.all i did was cut the exhaust manifold from the go-devil and welded it to the flex in the max.
also,the 23 has been sitting up for a few months,it cranks up and will run for a few minutes,then it dies and will not crank.wait a while,it cranks and dies again.i have the carb off to clean it,hopefully clogged jet or something.i also found out there are two wires going to the carb.like on a yamaha.
any advice would be appreciated.
   if it don't float with out you getting wet .  don't bring it !
    R.I.P  sage rogers   4 11 09  .
