Hi all
Slightly of topic as my engine is not on a 6 wheeler.
I have a Honda GX 340 GC05-3127412 the engine smokes at start up and all rpm's continuously. It starts perfect and runs perfect just smokes bad.
Things found
1. Looks like the valve stem seals are hard and probe not sealing. Is this a possibility?
2. I removed the head and there was about a 1/2 eyedropper amount of oil on top of the piston, the piston was clean and no carbon build up on it.
3. The cross thatching looked very good with a small amount of horizontal scratches. I need a bright light to see them.
4. I used a drill to turn the engine over for about 1 minute with out the spark plug in to see if oil was getting past the oil ring. After 1 minute there was a small film of oil forming on the cylinder wall above the piston. Is that normal
Do I need new rings and re hone the cylinder wall?
Should I replace the valve stem seals.
I have tried to look up the S/N but am unable to figure out the code (QC, V, K1 ETC) any help would be awesome. This engine is for a Amish friend of mine in northern Maine and just needs to be running normal.
Thanks All
Larry
Things found
Thanks All
Larry
