Compression 110psi, New Carb. 14-16 Kohler, Great spark, Good key in flywheel,
Starts and runs on Starter fluid and then runs crappy until warm. 5-7 minute, Coughs back though the carb., back fires, it will die if you don't coax it along. If you play with the choke and get it warm, is runs fine. Idles a little fast for the centrifugal clutch. Gas is new. runs strong at high RPM.
If the Compression wasn't so good I would suspect intake valve issues but 110psi sounds like factory? Since it runs good once warmed up I suspect the carb is fine, perhaps an issue with idle adjustment but that doesn't explain the starting issues. once warm I can't reduce the idle screw far enough to get the idle low enough for the Centrifugal clutch.
I went with the Kohler carb because the original Tecumseh one was crap.
