engine swap questions
  • engine swap questions
    couple of questions friends. is the bolt threaded into the shaft on a 16 vanguard right or left handed threads ? also when refitting a manifold with new flanges is it o.k. to bolt them to the motor then tack weld them to the manifold for final welding ? won't hurt the motor electronics or wires ? thanks always, johnboy va.
    RIGHT ...YES
      Right hand, the PTO end turns counter clockwise so it would need to be right handed to do any good. welding will not hurt the electronics or wires but i've seen b b's or slag jump into a cylinder in the past.
        thanks, that's what i thought on both. appreciate the reply ! will post when new engine is in the highboy max 2 and performance results !! johnboy
