or send me a PM and i'll give ya my number and you can call if that helps ya
No spark issue after motor swap. Hustler 950
Not to disrupt this but quick question for nubs. Very. And hor. Heads the same?sigpic
Ok....now we have spark, the 6 pole ignition is wired correctly, the gap on the coils are correct, COULD it be that my valves are too tight? Pulled the valve cover off to check things out and there is zero gap. I will set the lash at .05 and see if that helps.
THANK YOU for all the help!
IT'S ALIVE! If I tell everyone what the problem was you can't make fun of me since I am not to engines(I work on cnc machine).....When I put the heads from the 14 on the 18 I set the valves too tight and was not getting compression......
Fired right up. I need to make a bracket for my choke and throttle since the gov has been removed.
