In my hustler, I have what claims to be a 12 horse Tecumseh, based on the sticker on the pullrope. After a shot of starting fluid, the throttle held wide open and a pull or two, it fires right up. However, when I engage the transmission levers, the motor quits. I've tried it with full throttle, and just above idle. Sometimes I can get it moving, but it will randomly quit, sometimes on turns, sometimes uphill, and sometimes just on flat land.
The carb was bathed in a chemical solution (can't recall the name of it), and the spark plug is good and clean. Is it just a problem of the motor not having enough power to move the machine? Or do yall think something else is going on. It has brand new chains and bearings by the way. Transmission has fluid in it. 4 tires have slight flat spots, 2 have major flat spots (I put them in the middle though). Tomorrow I can take the good tires off the max and loan them to the hustler for a test.
