I'll be the guinea pig on this motor.....
  • I'll be the guinea pig on this motor.....
    Found this motor on ebay. What the heck I'll give it a shot and review.
    Powerland PD420E 16HP Gas Engine Electric Start | eBay
    If they are anything like the Predators if a small machine they should be great.
      I'm going to put it in a Max II. At the price I had to take the chance. We will see....
        Do you use the 1 gallon fuel tank and carry extra on board?
        ST400R ATTEX(Smiley)
        500 Super Chief
          We had ours going to the stock aatv tank and they make a pulse adapter that goes between the carb and intake and you can hook up a pulse pump. Of you can run a low PSI electric. Done both. We have a new in box 16hp predator sitting on the shelf after switching to the 22hp's.
            How do the Predator 22's do for you? Wouldn't happen to have a comet 780 you want to sell would ya?
              My plan for the gas is hooking up the pulse pump on the valve cover to into carb from stock max tank. Is this how you do it too Toys4Me?
                These are what I've used and they worked well. affordablegokarts: Carb Insulator w/Vacuum Takeoff
                  So far the 22's have been great only issue we've had is having to reroute the crankcase breather.
                    Toys4Me was that a sticker or painted on ( mud level in sig picture)?
                      That was a vinyl decal I made and put on.
                        How do they do the low oil pressure shut off with splash lubrication?????
                        is there a charging system?
                        if not add an external alternator with this pulley
                        Billet V-Belt Pulley for use with Comet 780 Clutch & Starter/Gen
                        Acta non verba
                          That was my first thought lol
                            they probably meant a low oil level shut off and something got lost in the translation
