I have a Max 2 clone with the Briggs 18 hp Vanguard Twin. I live in Mexico so it's not easy getting stock Briggs parts. Can anyone tell me what non-Briggs oil filter and spark plugs they use? I've tried looking up the interchange but find a wide variety of recommendations. Thank you for any information. I'm glad to have found this forum.
18 hp B&S Vanguard parts interchange.
I don't have any go-to brand when it comes to the oil filter. I typically go for an NGK spark plug but I don't know the part number off hand. You should be able to either cross reference that or perhaps order something online over the border before you need it.
Plugs should be: Champion RC12YC; Ngk BCPR5ES
Filter if its actually a Briggs this is what I have found in the past.
Briggs Vanguard Oil Filter Cross Reference
Filter Cross Reference for K&N Part HP-1002
Use this cross reference as a reference guide only! Use our application search to determine the K&N filter that correctly fits your vehicle.
Short Filter
492932 briggs short filter
fram PH3614
Fram PH8170
stp 3614
NAPA (Wix) filter, FIL 1056.
Wix 57035 51056 51065
beck 041-0767 041-8078
bosch 0986452058
carquest 85065
champ lf503
crosland 2099
tecumseh 36563 36961 740057
Tall Filter
Manufacturer Part Number
AC PF1245
AC PF1787
AC PF53
BRIGGS 491056
CHAMPION LAB. PH2835
FRAM HP7
FRAM PH3614
FRAM PH6022
FRAM PH7575
FRAM PH9342
FRAM PH9566
KOHLER 5205002
KOHLER 5205002S
MOBIL1 M1102
MOBIL1 MO241
MOTORCRAFT FL793
MOTORCRAFT FL910
ONAN 1220645
PURO L10028
PURO L10241
WIX 51215
WIX 51348
WIX 51391
WIX 51785
WIX 57023
WIX 57181
I found this online at some point and do not know how correct the info is but it may give you something to start with.sigpic
Thanks for the info. When I started digging into some of the specs for the oil filters there was some varience in gasket thickness and other details. I finally decided on the fram 8170. I like Autolite spark plugs so I'm going for the autolite 3923 plugs. There is an Auto Zone in the capital of this state. It's a couple hours away but they do have a good selection. Thank You for the help. Glad to be part of the porum.
