Wound up getting two 18 hp vanguard pump motors in a deal for a hustler. Have one in the Max 2 right now which sports 22" GBC gators. It takes it a little while to get up to speed, and if I bump up to a fallen log with an 8" diameter and give the max throttle, it doesn't go anywhere, motor doesn't try to spin up. Going to throw in some new spark plugs and move the governor spring over a slot to get more leverage over the arm. I was told that the motors had low hours as they had been used by a small town's volunteer fire department before being replaced by 23hp motors.
Any other ideas as to the lack of power?
On a side note, the motor squeals real bad when turned over by hand. Took the valve covers off, and saw that it only squeaked when one side's intake valve was returning to the closed position. No squeal after, and no squeal when the valve is getting pressed down. Sounds like it is coming from the cam area, sprayed a few things with wd40 to no avail. Attributed it to the motor sitting for years. Would this have anything to do with the lack of power?
