pull the generator head off and post a picture, the adapters work well although i have not used the one posted. the cranks are not easy to replace, gotta pull the pistons n rods in order to slide it out.
20hp vanguard
Ok I posted a pic in the gallery I have a hard time trying to post pics on here!! It's in the engine forum.Originally posted by Nubs View Postpull the generator head off and post a picture, the adapters work well although i have not used the one posted. the cranks are not easy to replace, gotta pull the pistons n rods in order to slide it out.
Thanks
My main concern is even if you lock the tapper adapter on with Green locktite and the end bolt will it NOT slip under a good hard clutch pull ?
I have seen key stock shear already.
Last time I had an engine with this crank in it I pulled it and turned it down and milled a key way in it.
Well Wedge I haven't a clue but none of my 2 strokes have slipped that I'm aware of. I got a tapered clutch that's not quite right so we are taking the shaft out of generator armature and turning it down to make a sleeve to go into the clutch. We are taking the taper out of the clutch as well!! Not sure how this will hold under a load but I guess we're gonna find out. LOLOriginally posted by wedge View PostMy main concern is even if you lock the tapper adapter on with Green locktite and the end bolt will it NOT slip under a good hard clutch pull ?
WISH US LUCK!!!
Originally posted by dave phelps View PostI wish these generator motors had that same taper!!! LOLOLNubs, do you know what the gen. Taper is, some older 2 strokes had 25mm tapers so those clutches are out there.Originally posted by Nubs View Post4 stroke snowmobile engines push well over 150hp and all run the M30 tapered pto's.
just sayin'
It will be a press fit with green loctite.I have 155 dollars in this whole deal so far so if it doesn't work I'll move to plan B! LolOriginally posted by Nubs View Postanything hand whittled is gonna be a problem, a tapered shaft or bushing needs to have a 100% surface contact. balance would be another issue i would think..
Wish us luck!!!
Good luck on this one . I am interested in seeing if there is an adapter ?
