Any help on this matter would be appreciated. I have been rebuilding a 400 chief over the last few months and finally got it fired up. After getting it fired i put the exhaust header on to connect the motor and muffler. As soon as i did the motor died down fairly drasticly. I figured there was a restriction in the muffler so i ended up cutting both ends of the muffler off to clean it out but i could not get to the baffles in the middle. I cleaned it the best i could, let it soak in muratic acid and heated it in a burn barrel to get anything out. I welded it back together and put it back on and it is still doing the same thing. I was curious if there is something still inside in the baffles blocking it or if they are designed to have some restriction. I can get it to idle if i turn the idle screw up but it seems like the motor keeps loading up. Any help would be appreciated, thanks.
-Matt
-Matt
