Hi All
I have a issue with my 18hp Vanguard and I will try my best to put all info in the post.
1. year 2000 vanguard 18hp
2. year 2000 max II
3. Exhaust Restrictor plugs removed. stock exhaust
4. High Rev kit, stock flywheel
5. Carb main jet drilled 1 size up. I believe .016 or .020 , been a year since I drilled it
6. Gov. disconnected and new linkage installed using another members schematic.
7. Valves set to proper gap.
The above was what was done to the engine a year ago. I have a tiny tach and the past 38 hrs of drive time the engine ran perfect, idled great, revved up great. I was extremely happy with the power and performance, I rarely went above 4400 RPM due to not having a Billet flywheel,
Now it has been 2 months since I have driven it and yesterday lots of issues.
I put fresh gas in the machine and the engine started right up as usual but it went to aprox 3k RPM and stayed there. I tried turning the idle down and a slight CCW turn and poof the engine died. Started it back up with no issue and back to 2700-3200 PM. then it would backfire like freaking crazy when I would snap the throttle to try to get it to idle. The engine will either die or stay at high RPM, I took it out in the woods near my house and under load it worked great as long as I was on the throttle, Under load it would die if I came off the throttle. No load high rpm. and of course when the few times I could snap the throttle and the rpm did come down it would back fire like crazy, sometimes once sometimes rapid backfiring.
Sorry for the long post I wanted to try to get all the info I could think of. Any clue what could have happend? went from good to not good due to sitting.
Thanks
Larry
2. year 2000 max II
Thanks
Larry
