can an EFI engine be manually started??????
  • can an EFI engine be manually started??????
    so last weekend I put a new starter in my 750 HDI argo.its a 2012 with under 3000km on it and roughly 250 hours.damn thing would not turn the engine over periodically. am gonna pull it apart tomorrow and see if its just dirty.anyhoo it got me thinking that if I was at the camp or anywhere for that matter and had a starter fail or a battery die on me,how can I get this sucker started? can you get a strap wrapped around the clutch and start it or is a guy completely FUBARED?
    Dead battery you're probably done, need power for fuel pump, computer etc.., if just the starter dies than perhaps a rope/strap somewhere. Be sure you go the correct rotation.
    Give it a shot, let us know.
      I don't think it will work, even though the tranny is basically a differential, it performs like an automatic transmission, which you can't pull start. Then you also have the fuel pump and computer issue to contend with. A jump box or an auxillary battery is really the way to go.
        As Jim and Noel both mentioned with dead battery you are done. I have" rope" started the 27-29 hp Kawasaki Maxs in the shop to see if it could be done. Use a flat strap and duct tape to hold it on the primary clutch and it's possible. Maybe with luck in an Argo. I've had much better luck getting a near death starter to give one more crank by beating on it while someone is holding key in the start position. A jumper pack will run an injected Argo until it gets to about 9 volts, the pump ect just quit between 9-10 volts.
          Hey Plott I have started my "Veng" with a strap once so yes can be done Battery power a must carry a starter pac if you are going miles from nowhere also check your neutral switch some times its only a switch issue and or the key switch the starters on them kohlers are pretty stout I replaced one in near 4K hours and it wasnt the issue.NCT
            Good point NCT a bad neutral safety switch or connection, be it nss, ground or battery cables will do the same.
              the old starter would attempt to crank but sometimes never had enough jam in its butt to turn the engine over.almost like it was coming up on compression stroke but could not overcome the resistance.anyhoo the new starter solved the problem.was just thinking out loud.
                Costly little beggar isnt it Iam amazed at that small amount of hours and shes pooched they are not exactly user friendly to replace either gets ya thinkin what went wrong and why.NCT
                  well I have not attempted to manually start the argo because of a sore back but i did rebuild the starter.pulled it apart and cleaned it in the parts washer,it really was not very dirty.cleaned up the commutator with some krokus cloth then put the new brush set in.re-installedtor. it and it seems great,cranks over immediately with no effort.the old brushes looked ok so I think the problem was a bit of glazing on the commutator.
                    Great news Plott new ones break the bank did Argo supply the brushes what do you suppose caused the glazing?
                      not sure what caused the glazing and I'm sure that the warranty is over.but last year I bought a bunch of NOS from a guy going out of the small engine business.new fuel pump,starter and a bunch of other goodies.so ive ended up with an new spare starter again with the price of a brush set.
                        Beautiful Plott grab them deals when you can get them gotta say mine has been no issue yet so something couldn't have been wright from the factory with that starter too early to fail.NCT
                          Isn't Plott's machine a 2012?
                            yes jim,its a 2012.was a factory demo.
                              Mines a 2003 with 4K plus hours Plotts is brand new in comparison for hours jus seems hard to believe that it would fail so soon Jim and his machine is well taken care of sits in a cathedral he calls a shop mine sits in the bush alot LOL.NCT
