Is there any physical difference in the size of the blocks or are the blocks the same and the bore and stroke where the extra power comes from? My vanguard had a 16 in it when I got it but it's toast and I found a 18hp vanguard that I hope just drops right in after I swap over the throttle linkage and whatnot. Let me know if there's anything about this swap I should know please fellas.
16hp and 18hp Vanguard
Originally posted by wedge View PostWhen you go to move the key set up you will see it is real simple ! Just cut and extend the wires to where you want to go. But use self sealing connecters !
Would also make a decent anti theft switch.
