Trying to post pics of this clutch mounted. I have such a hard time figuring this out. Hopefully this works or may as well delete this post!
Thanks
Ok fellas. This is pic of the sleeve from generator we milled and pressed this inside of this clutch. Not sure if it will work but our only next step is to try to cut more taper in the clutch to get it closer to the engine!! Not sure I have enough metal left to do that!!
Thanks for all your input on this trial and possible error!!
Looking good dave. You should have plenty of material to get it closer but if you have the room it should be ok hanging out that far.
It has an 1 3/4 on the crank but we were worried about trying to cut the taper any deeper into the clutch!!
Time will tell!! Worried about the torque!!
Fingers crossed!! Lol
