Kohler Command 20 Fuel Pump Question
  • Kohler Command 20 Fuel Pump Question
    I have a hustler with a Kohler command 20. Fuel pump is bad. It's built into the valve cover. eBay shows new valve covers with the fuel pump for 80-100. My question is, is do I need to buy a whole valve cover? Or does some one sell the fuel pump that I can screw on?
    Have not taken the valve cover off to see the underside, has been raining and I don't water in the motor.
    Meep Meep
    The only way I've gotten that pump is as a unit. Kohler usually supplies it with several fittings. Follow instal instructions on fittings or the o-rings get damaged. I don't know why but have not been able to find any repair parts for that pump yet.
      Yep,same here. Only available as a unit. May want to consider an electric pump
        Go on e/bay and look up a Cud Cadet fuel pump. The 2100 series had the Kohler engine in them. That's what I am using in my StarCraft.
        I have seen Just the pump on there (new) for Less than the one with the V,cover.
          OH and the pump dose mount on with screws.
            The diaphragm inside is the same from the KT17 up, I did it on one giving me issues before I bought the cover, recently I found a kit on ebay but lost it.
