Time for another question. I have the max 2 with Briggs 14 hp motor. I have replaced all the fuel lines front to back, installed new inline filter, and now a new fuel pump. I am not getting any fuel from the pump to the carb. Racked my little pea brain all day. Help please.
Briggs 14HP No Fuel
I had to do this with my Max IV. Used the air compressor and nozzle. Opened everything right up. Changed the fuel filter after about 10 mins of running. Cheap insurance.Originally posted by glennmac View PostTry blowing backwards through the line. You should be able to hear air bubbling in the tank. If not you are now on to something.Immature. A word used by boring people to describe fun people.
If you haven't started on this yet 2 quick checks, is the fuel shut off turned on if so equipped and did the fuel line get pinched after rerouting and the upper body sitting on it?sigpic
Does say if it is eletric fuel pump or pulse pump. Recheck pulse hose and other lines to see if you have them in the right place. The if have anti after fire solenoid make sure it is working correctly. Spray little either in the carb try to start. If it does start might not be firing and if it does and then quits most likely and fuel problem.
