Walbro WR5 or swap???
  • Walbro WR5 or swap???
    I just put a kit in my walbro...now I know the pump is working because it just SPRAYS fuel into the carb...so something's not right. What size mikuni slide should I find for this beast and be done with all this. I'm getting a little more than frustrated with this Wally....
    Are you sure pump lever is set correctly? It is very sensitive I learned.
    ST400R ATTEX(Smiley)
    500 Super Chief
      I did the best I could following everything I could find...but I'm utterly new to walbro
        well, because i'm an idiot, I assembled it without the spring under the needle valve...so yeah...it runs now...but only under some throttle..I gotta work out some idle problems.
