Originally posted by dirtdobber
View Post
18 hp briggs and stratton smoking
Adjust the valves, one may be too tight allowing some compression to escape. Redo test.Originally posted by Trapper Dano View PostJust did a compression test on the motor a hair under 90 on the front cylinder and about 165 on back cylinder? the smoke is white
BTW when we bent a pushrod our machine smoked violently.Last edited by ARGOJIM; 04-25-2017, 10:04 PM.sigpic
Checked the push rods they are all straight. picked up a feeler gauge but wont get a chance to work on the machine again until Thursday night likely, will check all the valves and set them all the same between .004 and .006 Correct?Originally posted by ARGOJIM View PostAdjust the valves, one may be too tight allowing some compression to escape. Redo test.
Snuck out of work at lunch. Checked the tappets adjusted one a tiny amoumt all are .004 did a new compression test still 90 in the front cylinder and 170 in the back. Could it be my compression relief?Originally posted by ARGOJIM View PostAdjust the valves, one may be too tight allowing some compression to escape. Redo test.
One side was 90, and the side I pulled the head on was 170. When I did the pull the pull the plug wires test, unplugging the 90 cylinder caused it to run rougher, whereas unplugging the 170 cylinder caused no change to the way it ran. I thought that indicated that it was running more on the front cylinder the 90 one than the back one the 170? And isn't 170 too high? I thought I read that 90-110 was more normal?Originally posted by dirtdobber View PostJust curious.....why did you pull the head from the good side (higher compression side)?
I'm not sure what normal is for these engines, but 170 does seem high. If I'm applying the right logic, pressure and volume are proportional. With atmospheric pressure being 14.7 pounds, and assuming the pressure inside the cylinder on the intake stroke is 14.7, then then it has to compress 11.5 times to reach 170 psi. A good old stock Chevy small block engine would have somewhere around a 8.5:1 ratio, but I'm not sure what these engines should have. But, I can't think of anything that can go wrong and cause increased compression, unless maybe the exhaust valve is not opening and the cylinder is able to draw in a little more air than normal and thus is reading a higher compression (that's just a wild guess, by the way). Especially since the compression on one cyl. is nearly double the compression on the other. You did read your gauge right (psi) and not some other units??And isn't 170 too high? I thought I read that 90-110 was more normal?
Post some pics. Not sure if they will help but pics are always fun to look at.
20170501_192350.jpg20170501_210325_001.jpg20170501_210759.jpg20170501_192350.jpg20170501_210325_001.jpg20170501_210759.jpgOriginally posted by dirtdobber View PostI'm not sure what normal is for these engines, but 170 does seem high. If I'm applying the right logic, pressure and volume are proportional. With atmospheric pressure being 14.7 pounds, and assuming the pressure inside the cylinder on the intake stroke is 14.7, then then it has to compress 11.5 times to reach 170 psi. A good old stock Chevy small block engine would have somewhere around a 8.5:1 ratio, but I'm not sure what these engines should have. But, I can't think of anything that can go wrong and cause increased compression, unless maybe the exhaust valve is not opening and the cylinder is able to draw in a little more air than normal and thus is reading a higher compression (that's just a wild guess, by the way). Especially since the compression on one cyl. is nearly double the compression on the other. You did read your gauge right (psi) and not some other units??
I thought the same thing that it was too high and had no clue how it could get that high. I retested both cylinders 5 times always got the same readings 90 in front and just shy of 170 in the rear cylinder. I too am baffled. I know very little about small engines but I think the head looks normal, doesn't look like any of the other ones I had been able to look up with head problems. The gasket is good, and I am able to hand compress both the springs and both valves open?
Stupid question did you have spark in both cylinders at the tester and the plug? a dead plug or burnt diode will cause poor performance and rough running.
Perhaps Nubs knows the rough compression readings.sigpic
Yeah Jim i have spark in both, even put brand new plugs in it.Originally posted by ARGOJIM View PostStupid question did you have spark in both cylinders at the tester and the plug? a dead plug or burnt diode will cause poor performance and rough running.
