18 horse power Vanguard high rpm miss
  • 18 horse power Vanguard high rpm miss
    This is probably a stupid question but is this mouse damage enough to cause a miss?
    It can as the Voltage will leak through and lessen the spark out put at the plug.
    But this will happen and Low rpm also. when are you seeing the miss ?
      Close to max speed at wide open throttle, governor is stock never touched it
        Ok that helps ! Is it a spark miss like flipping the switch or Fuel miss like Leans out and starves one bank ?
        You can look at the plugs also. If thy are White and clean it is Fuel. Black and sooty then Spark.
          OH and get a CAT or a mouse trap as the mice tend to make you spend money !!!
            Right on, pulled plug on that cylinder, was black and sooty, front plug looked good, this engine only has about 6 hrs on it. Just put new coil on, off to test drive...
              That is SPARK for sure !
              Let us know how it turns out.
                Much better now! Thanks Wedge.
