Vanguard timing key
  • Vanguard timing key
    Simptoms of sheared or partially sheared key? 16hp
    Has good compression,spark on both cylinders but weak power, new carb.
    Just push me to pull like I should, but with symptoms.
    Thanks.
    OK Jim I will Bite ?
    I have ran Offset keys in the Cart engines before for more power on the top end But are you saying you have this issue or found it out ?
    I found this out when I put one in Backwards by mistake ! Did A lot of digging before I looked at what I did wrong !!LOL!!
      exhaust restriction?
        Well Jim, are you going to tell us what was wrong with this engine?
          Not yet, didn't look.
