Have any of you added an alternator to your Honda clone engines? Im going to need the extra juice when I get my max buttoned up since I'm going to have enough lights that it will probably look like a space ship plus, cb, stereo, winch, heater fan, and 7 inch fan to help cool in the summer time. If I can I'd like to just put a v belt pulley on beside my clutch, just seems easiest I should be able to find a 1 inch shaft keyed pulley just about anywhere local. That is if there's enough room to mount the clutch with a pulley behind it.
Alternator on clone engine
I just got the Duromax 7HP with electric start, I'm putting it in a small scale jeep I'm building to run around in, I want to hook up a set of head lights but there's no wiring diagram that says what wire does what. The battery cables are already connected so really I just have to install it and get a battery. Can I just run power straight from the battery to a fuse box with a switch in between to cut off power to it when not in use? Then run my lights off the fuse box? Any diagrams or suggestions will be greatly appreciated.
