I just went for a ride and when I got back I heard a bit of a whining/grinding. Looks like my clutch is rubbing on the rotor. Is this adjustable or do I have a major issue? Thanks
Rotar Catching Flywheel
Check the clutch buttons first, then check that the snapring is in place, check the manual as there are spacers available, lastly I'd suspect the clutch bushing is wore which will allow the inner face to wobble.sigpic
I've never worked on clutches much, but got home from work last night and had a look. You're right on, the clutch buttons are worn down and there is play between the backside of clutch and them, causing it too catch rotor. I can pull it tight/closer to pukka by hand. I'm guessing that means the clutch retaining ring is gone/broken? Does the whole clutch assembly have to come off to rebuild it?
I had a neighbour today show me an old parts machine in his field. Serial number looks like it's a 1985 eight wheeled machine. The clutch looks the same, does anybody know if it will work for my 97 Vanguard 6 x 6?
The model on parts machine is TB3485. I found the TB in parts manual but not that numberLast edited by utah; 09-02-2017, 02:25 PM.
Take a picture of it. I do not believe so. There is a manual on the home page to repair your clutch, new buttons and new bushing will freshen it right up. The snap ring I was informing you of only holds the clutch together and should be visible while in the machine.sigpic
