Hey, so i have a 2017 Argo frontier with the 19HP Kohler. Went out for a ride last night and all of a sudden the engine was stuck at 3200rpms. Of course i was in gear so it wouldn’t stop until i turned the key off. I put it in neutral, started it up again and still was sitting at 3200 rpms just screaming. The throttle cable was not stuck or anything. Removed the battery cable for 5 mins(reset the ecu maybe) and it fixed it... just wondering if anyone else has had this happen to them?
2017 argo stuck at 3200 rpms
I had my 2016 Frontier do this once with the 23 hp Kohler. Couldn’t shift to neutral with it revving but finally I was able to get it down to idle by flicking the throttle (I thought anyway). Only happened that once.
My oil light is usually on too (sometimes goes out) and I know the oil is good...just did a full service on it.
Don’t know where the sensors are so can’t check them.
You have a three year warranty and your guage is out of whack. Your dealer can use past experience or his computer to reset your guages but is is a bit complicated. why take a chance if your oil light is on.?Originally posted by argo6x6! View PostUpdate, now the oil light and engine light are coming on/off as you ride. Oil level is fine and seems like there;s lots of oil pressure.
