I got my Predator 22hp from HF the other day. I know it's an easy swap from B&S 18hp. Mounting won't be an issue, shaft size matches, etc. Started looking at the wiring on predator key switch. For some reason, I have it in my head that I need to re-wire key switch so I can keep the new OEM switch I got from Max / RI last year. They're wired differently, so that throws me off that much more. I was able to get some tech info from a couple of members (thanks Jeff & Ted), but I still have questions.
Q. Can I stay with predator switch and just add a wire for lights when in "On" position?
Q. Can someone explain where I would attach new wire for lights on switch?
(There are several open spots I could solder new wire to, but don't know which one I
should use) there are also numbers stamped next to each terminal.
Q. Has anyone with this motor changed over to OEM key switch on their machine?
Q. Am I thinking too much about this f*&^%g switch?
Thanks...
Thanks...
