Have just partially rebuilt a Kohler KT17, using new battery, coil, leads, condenser and plugs. Checked voltage is getting to coil from RUN position, and continuity to earth all okay. Points are opening and closing, .020" gap. I have a new set of points, but the old ones looked fine, not burnt at all. Absolutely zero spark, so I am assuming something simple. The only thing of note is that somehow the battery was connected in reverse, obviously rectified, bht could this have wiped out condenser ?
Kohler KT17 No spark
did u make sure staor and flywheel were clean. stator contacts may be dirty and i would remove it as i believe it has some sort of ground to the engine .check stator wires as well. like i said im not used to condensers and points so someone else will have to help but other than that make sure coil gap is 0.10 all plugins are connected properly and new plugs
Originally posted by Malxwal View PostOkay. No sign of anything loose on flywheel. Showing my ignorance, but thought that would only result in not charging. Anyway, anything else I may be missing ?sigpic
