Ok guys, I'm looking for an answer to a question, but first the background:
In my Hustler 950, I just did an engine swap. I removed a 20 horse opposed Briggs and replaced it with a 18 horse opposed Briggs. I used the cowling and the carburetor from the 20 horse, and the same exhaust set up. The only substantive difference between the two engines is 2 horsepower, and the 18 horse has the pulley on the flywheel for rope start, if needed. The 20 horse ran fine with no heat related issues.
I took it out yesterday and rode about 10 miles, most of which was hard ground. At the beginning of the ride it ran fine. After a while, it would not idle and was hard to start. I would have to hold the throttle wide open with no choke for it to start, and it wouldn't run under about 1500 rpms. This morning, it ran fine. I assume the fuel was boiling and keeping it from running right.
The real question is why? It's the same engine as was there before with no issues. The only thing I can think of is the flywheel may be different in its ability to move air.
What do you guys think?
