kohler magnum 18hp weak/loss of spark
  • kohler magnum 18hp weak/loss of spark
    have a argo magnum with a 1991 18hp kohler that wont start.
    weak spark on rear cylinder none on front .
    tested for spark with a known good plug.
    checked and cleaned all connectors to engine,replaced some corroded ones.checked earth points,
    disconected the 2 engine ignition interupt (earth)wires from switch.still the same.
    is the flywheel pick up sensor part of the coil?
    any ideas
    weak spark
    Hey , did you get this running yet ? , no spark , weak spark is often caused by the magnets on the flywheel or coil pick up ends being dirty , rusty or corroded from sitting withought running , clean them up till they are shiny new and check for the proper gap , use a scotch brite pad with a little solvent to clean them off , useing steel wool will work but your going to get little peices stuck all over the magnets and you have to clean them off or they can short to ground , it's a pretty quick , cheap and painless .
