when i spray wd40 and carb cleaner and stuff i dont have the fuel line hooked up
what should i do about engine?
carb cleaner and wd-40 don't burn all that great. get a can of starting fluid or brake clean. even with that it won't run long. it will either burn it all at once, or you'll flood the engine if you keep trying to spray it. i would spend the cash on a carb rebuild. the carb delivers the right ratio of air and fuel... you can't really replicate that with a spray can, and can do dammage to the engine if you do it too muchA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
Hi:
If the needle O-ring is shot, it won't run. It's getting too much gas and flooding, making it hard to crank, pulls high amps, and bingo, you get smoke. I rebuild my garden tool engines all the time without kits, and am just VERY careful to not tear any gaskets, but you'll still need that O-ring, and the kit is probably very cheap anyways. AND BE CAREFUL, a hardware store O-ring may degrade in the gas very quickly, leaving you back where you are now in no time.Attex 295 Wild Wolf: sigpic My Runner
Attex Super Chief - Sold.
i replaced the oring and poured a bit of gas in the hole
it fired and the exhaust came out of the side of the head
then i tried again and flame shot out of the carb(was kinda like a flamethrower, pretty cool) so, i think the head is a bit warped and the timing is way off.
i think i need a new engine
i think my options are 8hp or 10hp tecumseh or 12hp LCT
any suggestions?
i cant spend much at all, definately not more than 400
oh and how do i get the thing off???????Last edited by Mike; 12-05-2008, 08:47 PM.
