does anyone know anything about the powermax motors on ebay? great price but I cant seem to find any info about them.....thanks....
powermax engine
Great engine.
I have the powermax 16hp electric start in my 208tt. It is a great engine and always starts. Even in 0 degree's. put choke on and pull the rope once and only once
. It doesnt seem to start as easily with the electric start though, cranks more. Not sure why that is. The only problem I have had is the plastic fan on the flywheel cracked. They did shipped me a new one free under warranty, free shipping and no questions asked at all. I did fry the coil but it was because the wires shorted out and put + to the ground side of the coil that shuts it off, my fault
. I got hot and I never did check to see if it would work after the coil cooled down but I did just by a genuine honda one cheap off ebay. Another problem you may or may not have is the low oil shut down. My engine was originally on a Kart and under heavy sharp cornering it would shut it down. I had to disconnect it and it was no big deal just wont shut it down when your low on oil. But over all It has been a great engine for the very low price tag. I mean I can buy like 3 maybe 4 of these engine for one 16 hp briggs vanguard. Which is also a great engine if you can afford one.
I do have a few videos of me climbing a hill and such on the video time section if you want to see it in action. Check out my profile and can find my post there. Once you find them you can go to youtube and see all the videos I have of it. User name on youtube is xljimmy from when I had a gmc jimmy. Also some videos there of the engine in my custom gokart I built too.
Larry
I also have their 16hp electric start. Mine is in a lifted golf cart. It only has about 14 hours on it but I've been very happy with it for the price. I split the case and removed the factory mechanical governer completely. I also tapped the hole that the governer assembly ran through and use it for a vacuum port for my fuel pump. I've kindda treated that little motor like I hate it and it keeps coming back for more. From what I understand the 16hp is 420cc and is just a factory bored and stroked version of Honda's GX390 which is 13hp. Supposedly all Honda parts will work which also enables a guy to use some of the performance parts out there for the Hondas.1984 Hustler 980 and some other toys that won't even swim.
Does anyone have a useful link to get parts or performance upgrades for this motor? I'm going to need a new carb or rebuild kit for the one I have as it is flooding the cylinder and case with fuel when you shut it off unless you also cut the fuel off at the cut off valve. I can only take this to mean that the float is stuck. (Also, the engine only runs with the choak full on)
I thought this may be a good time to get a better carb, and exhaust pipe, something that is sporty would be nice.
Any thoughts?Every time I have to push 1... I buy 10 more bullets
look for GX390 performance parts from the buggy and kart guys. A sh!t load of performance parts are availaible for this engine.Originally posted by vanmeterj1 View PostDoes anyone have a useful link to get parts or performance upgrades for this motor? I'm going to need a new carb or rebuild kit for the one I have as it is flooding the cylinder and case with fuel when you shut it off unless you also cut the fuel off at the cut off valve. I can only take this to mean that the float is stuck. (Also, the engine only runs with the choak full on)
Any thoughts?2008 MAX-IV 500T 30hp Bandolero
I bought a few parts from this place for my clone Honda.
Affordable Go Karts - Home page - AGK - http://www.affordablegokarts.com1984 Hustler 980 and some other toys that won't even swim.
Ok, I have a new Question. I am looking for a drive shaft extension that will fit this motor. I did find a Toro extension that seemes to be a good looking deal but I wanted to make sure there was not a bearing based extension cone. I have seen them on other types of motors that are used in Blackwater based designs.Every time I have to push 1... I buy 10 more bullets
